Ir para o conteúdo principal
Sony Clie PEG-NR70 Memory Module Replacement
O que você precisa
  1. Sony Clie PEG-NR70 Memory Module Replacement, The Case: passo 1, imagem 1 %32
    • Unscrew the 1.9mm screw located at the top of the device with a Phillips #00 screwdriver.
    • It may be helpful to set up a piece of paper to keep track of where removed screws came from.
  2. Sony Clie PEG-NR70 Memory Module Replacement: passo 2, imagem 1 %32
    • Unscrew the 2.5mm screw located on the left side of the device with a Phillips #00 screwdriver.
  3. Sony Clie PEG-NR70 Memory Module Replacement: passo 3, imagem 1 %32 Sony Clie PEG-NR70 Memory Module Replacement: passo 3, imagem 2 %32
    • Unscrew the five 2.5mm screws on the back panel with a Phillips #00 screwdriver.
    • Remove the back panel by lifting it away with your hands.
  4. Sony Clie PEG-NR70 Memory Module Replacement, Memory Module: passo 4, imagem 1 %32
    • Holding the memory module in place, unscrew the three 0.9mm screws with a Phillips #00 screwdriver.
  5. Sony Clie PEG-NR70 Memory Module Replacement: passo 5, imagem 1 %32
    • Lightly grab the memory module and pull it upwards.
    • Make sure you grab the end closest to the edge of the device. You may have to wiggle the module a bit to get it to come free.
Conclusão
Daniel Soski
Membro desde: 04/18/13
57 Reputação
Autoria de 6 guias
Equipe
Cal Poly, Team 14-11, Maness Spring 2013 Membro de Cal Poly, Team 14-11, Maness Spring 2013
CPSU-MANESS-S13S14G11
Membros da 5
Autoria de 8 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 4
Duração total: 554
