Introdução
Use this guide to replace the function and volume buttons on the top of the speakers if they are broken.
O que você precisa
Remove two 6mm Phillips #0 screws.
Remove two 7.5 mm Phillips #0 screws.
Remove seven 4 mm Phillips #0 screws.
Using the plastic opening tool, detach the wires connected to the metal plate
Use the plastic opening tool to remove wires connected to the circuit board on the far right.
Use the tweezers to remove wires connected to the circuit board in between the two black wires.
Use the tweezers to press the release tab on the front and back of the plastic white wire head.
Once the tab is pressed on both sides, lift up to slide wire head out of socket.
Remove two 6 mm Phillips #0 screws.
Gently lift the silver buttons up to remove.
3 outras pessoas executaram este guia.
