Introdução
This guide will demonstrate how to replace the batteries for your radio.
O que você precisa
Press down on the two tabs at the top of the door.
Rotate the door away from the radio, towards you.
Lift the door out of the three smaller tabs on the bottom.
Push the batteries against the spring and pull out using your finger to remove them.
Quase terminado!
Conclusão
