Ir para o conteúdo principal
Sony CFS-204 Radio Cassette-Corder Batteries Replacement
O que você precisa
  1. Sony CFS-204 Radio Cassette-Corder Batteries Replacement, Batteries: passo 1, imagem 1 %32
    • Press down on the two tabs at the top of the door.
    • Rotate the door away from the radio, towards you.
    • Lift the door out of the three smaller tabs on the bottom.
    • Ensure the radio is turned off to avoid the possibility of electric shock.
    • The battery compartment door is not shown.
  2. Sony CFS-204 Radio Cassette-Corder Batteries Replacement, Batteries: passo 2, imagem 1 %32 Sony CFS-204 Radio Cassette-Corder Batteries Replacement, Batteries: passo 2, imagem 2 %32 Sony CFS-204 Radio Cassette-Corder Batteries Replacement, Batteries: passo 2, imagem 3 %32
    • Push the batteries against the spring and pull out using your finger to remove them.
    • To insert the new batteries, push the negative end of the 1st battery against a spring and follow the diagram pictured to insert the batteries in the correct orientation.
Conclusão
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 4
Últimos 30 dias: 29
Duração total: 1,924
