Introdução
Here is a full disassembly of the Sony’s CFD-S70.
O que você precisa
Using a PH2 screwdriver, remove the 5 screws in the holes
Don’t forget to remove the two screws circled in green
Open the CD cover and remove the two screws using a PH0 screwdriver
Move the handle up to unscrew the hole screws using a PH2 screwdriver
Turn the device on his back and pull back and up the bottom portion of the device
Remove the two screws with a PH2
Remove the connector on the left side of the mainboard
Stress the right side where there’s the audio connections and pull the main by the left
On the bottom of the main, gently disconnect the connector
Like the connector, remove the Flex cable from the main
Carefully flip the main and disconnect like the others the cables. You can now remove the mainboard
Now it’s time to remove the front of the device. There’s two little brackets on each side that is retaining the front
Using a flat screwdriver or any other flat and thin tool, pry the outside tabs working your way down and pull the front from the top of the device
To reassemble your device, follow these instructions in reverse order. Have fun :D
