Introdução
If your device is not turning on and you're using batteries as a power source, you can use this guide to remove or replace the batteries. Be sure to remove the batteries and unplug the device before taking it apart to avoid electric shock.
Remove the battery cover on the back of the boombox by applying downward pressure to the two clamps.
Quase terminado!
Conclusão
