Introdução
Use this guide if your radio is not working and the antenna needs to be replaced. This is an easy part to replace and requires a standard Phillips #1 screwdriver.
O que você precisa
Unscrew the screw attaching the antenna to the boombox with a Phillips #1 screwdriver.
3 outras pessoas executaram este guia.
