Introdução
This guide will show how to replace a motherboard. The motherboard could be causing faulty display, not turning on, and bad sound quality on a continuous basis.
Before any repair work can be done, one must remove the device from the vehicle. To do so follow this link to see a vehicle general removal of a stereo system.
O que você precisa
Remove one 9.5mm Phillips #00 screw.
Rotate device 180 degrees and repeat step.
4 outras pessoas executaram este guia.
