Esta versão pode conter edições incorretas. Mude para o último instantâneo verificado.
O que você precisa
Este passo não foi traduzido. Ajude a traduzi-lo
Press the battery release button.
While pushing the battery button, slide the battery to the left.
Open the cassette cover.
Unscrew 14 screws located on the outer casing. Three are located on the top face 2x6.8mm and 1X4.54mm, three on the left face 1x4.54mm,1x5.3mm and seven on the bottom face 5x4.54mm and 2x6.77mm.
Remove five screws from the right side, from bottom to top, 3x4.54mm 2x5.70mm.
Remove the single 4.5 mm screw from the backside.
Pull off the plastic tape cover by lifting it up and out of the camera base.
Disconnect the mic assembly by pulling it away from the camera base.
Pull the bottom part of the case away from the camera.
Remove the three 4.5 mm screws from the right face of the video camera.
Remove the single 3.6 mm screw at the front of the video camera on the circuit board.
Pull the audio/video inputs underneath the microphone assembly. The inputs should still be connected to the circuit board.
Remove two remaining 3.6 mm case screws from the front of the camera.
Ferramenta utilizada nesse passo:Tweezers$4.99-
Using metal tweezers, pull out the plastic connector box on the front side.
Again use metal tweezers to pull out the connection box on the bottom of the camera. The right side of the case can now be removed by pulling it to the right.
Using metal tweezers, pull out the plastic connector box located in the center area.
Pull up the circuit board.
Lift the lens assembly from the large circuit board.
Remove the two 5.3 mm screws.
Remove the single 6.1 mm screw using a Phillips #000 screwdriver.
Remove the lens from the lens assembly.
