Ir para o conteúdo principal
Sony Bloggie 3D Player On/Off Buttons Replacement
O que você precisa
  1. Sony Bloggie 3D Player On/Off Buttons Replacement, Front Cover: passo 1, imagem 1 %32
    • Remove the two 2.5mm Phillips #00 screws using the Philips #00 screwdriver.
  2. Sony Bloggie 3D Player On/Off Buttons Replacement: passo 2, imagem 1 %32 Sony Bloggie 3D Player On/Off Buttons Replacement: passo 2, imagem 2 %32
    • Use a plastic opening tool to pry the cover open.
    • After the the cover is partly open as shown, remove the cover with your hands.
  3. Sony Bloggie 3D Player On/Off Buttons Replacement, Back Cover: passo 3, imagem 1 %32 Sony Bloggie 3D Player On/Off Buttons Replacement, Back Cover: passo 3, imagem 2 %32
    • Using your hand, or a pair of tweezers, remove the ZIF connector by gently pulling it out of the dock on the circuit board.
  4. Sony Bloggie 3D Player On/Off Buttons Replacement: passo 4, imagem 1 %32 Sony Bloggie 3D Player On/Off Buttons Replacement: passo 4, imagem 2 %32
    • Use a plastic opening tool to loosen the back cover off the device.
    • Once the back cover is loose, remove it gently by hand.
  5. Sony Bloggie 3D Player On/Off Buttons Replacement, On/Off Buttons: passo 5, imagem 1 %32
    • Using a spudger, carefully remove the metal casing that is attached to the ZIF connector.
  6. Sony Bloggie 3D Player On/Off Buttons Replacement: passo 6, imagem 1 %32
    • Unclip the two plastic buttons with the spudger tool.
    • The buttons each have a spring under them that will fall off, be careful not to lose them.
Conclusão
Fred Saucedo
Membro desde: 01/11/13
3 Reputação
Autoria de 1 guia
Equipe
Cal Poly, Team 7-12, Maness Winter 2013 Membro de Cal Poly, Team 7-12, Maness Winter 2013
CPSU-MANESS-W13S7G12
Membros da 5
Autoria de 12 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Duração total: 280
