Introdução
Whether it's due to dust, wear, or physical damage, the main button circuit board may need to be replaced at some point. This guide focuses on how to install a new main button circuit board to get your Sony Bloggie 3D Player running like new.
O que você precisa
Remove the two 2.5mm Phillips #00 screws using the Philips #00 screwdriver.
Ferramenta utilizada neste passo:Tweezers$4.99
Detach the board from the ZIF connector using a pair of tweezers or by hand.
Flip the circuit board over and remove the connector on the backside. Now you can safely remove the circuit board.
Uma outra pessoa concluiu este guia.
