Ir para o conteúdo principal
Sony Bloggie 3D Player Main Button's Circuit Board Replacement
O que você precisa
  1. Sony Bloggie 3D Player Main Button's Circuit Board Replacement, Front Cover: passo 1, imagem 1 %32
    • Remove the two 2.5mm Phillips #00 screws using the Philips #00 screwdriver.
  2. Sony Bloggie 3D Player Main Button's Circuit Board Replacement: passo 2, imagem 1 %32 Sony Bloggie 3D Player Main Button's Circuit Board Replacement: passo 2, imagem 2 %32
    • Use a plastic opening tool to pry the cover open.
    • After the the cover is partly open as shown, remove the cover with your hands.
  3. Sony Bloggie 3D Player Main Button's Circuit Board Replacement, Main Button's Circuit Board: passo 3, imagem 1 %32 Sony Bloggie 3D Player Main Button's Circuit Board Replacement, Main Button's Circuit Board: passo 3, imagem 2 %32
    • Detach the board from the ZIF connector using a pair of tweezers or by hand.
    • Flip the circuit board over and remove the connector on the backside. Now you can safely remove the circuit board.
Conclusão
Robert Tam
Membro desde: 01/30/13
6 Reputação
Autoria de 2 guias
Equipe
Cal Poly, Team 7-12, Maness Winter 2013 Membro de Cal Poly, Team 7-12, Maness Winter 2013
CPSU-MANESS-W13S7G12
Membros da 5
Autoria de 12 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 9
Últimos 30 dias: 12
Duração total: 377
