Introdução
Whether it's by dust or wear, the Main Button's Circuit Board can malfunction over time. This guide focuses on how to install a new Main Button's Circuit Board to get your device running like new.
  1. Remove the two 2.5mm Phillips #00 screws using the Philips #00 screwdriver.
    • Remove the two 2.5mm Phillips #00 screws using the Philips #00 screwdriver.
  2. Free shipping on all orders over US$100,00 or containing a Pro Tech Toolkit!
    Visite Nossa Loja
    Ever fixed something? That’s Genius.
    Share your repair story with #ImAGenius
    We Are All Geniuses
  3. Use a plastic opening tool to pry the cover open. After the the cover is partly open as shown, remove the cover with your hands.
    • Use a plastic opening tool to pry the cover open.
    • After the the cover is partly open as shown, remove the cover with your hands.
  4. Detach the board from the ZIF connector using pair of tweezers or by hand. Flip the circuit board over and remove the connector that is on the backside, now you can safely remove the circuit board.
    • Detach the board from the ZIF connector using pair of tweezers or by hand.
    • Flip the circuit board over and remove the connector that is on the backside, now you can safely remove the circuit board.
Conclusão
Robert Tam
6 reputação
2 Guides authored
Equipe
Cal Poly, Team 7-12, Maness Winter 2013 Membro de Cal Poly, Team 7-12, Maness Winter 2013
CPSU-MANESS-W13S7G12
5 Membros
6 Guides authored
Visualizar Estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Todo: 276
