Introdução
Every battery runs out of power eventually after many uses. This guide will show you how to easily replace the battery on your Sonly Bloggie 3D.
O que você precisa
Remove the two 2.5mm Phillips #00 screws using the Philips #00 screwdriver.
Quase terminado!
Conclusão
Um comentário
You forgot to mention the need to flip the screen up (a screw holds it down) in order to get to a screw holding the back cover. Other than that, thank you for the info.
