Ir para o conteúdo principal
Sony BDP-BX520 Port Board Replacement
O que você precisa
  1. Sony BDP-BX520 Port Board Replacement, Disc Tray Cover: passo 1, imagem 1 %32
    • Plug in the Blu-Ray player, then press the power button, making sure the Blu-Ray player is powered on.
    • Press the eject button on either the top of the Blu-Ray player or on the remote to open the disc tray.
  2. Sony BDP-BX520 Port Board Replacement: passo 2, imagem 1 %32
    • Grab the sides of the disc tray cover and carefully pull each side upwards, starting with the left side. This will unhook the cover from the tray.
  3. Sony BDP-BX520 Port Board Replacement: passo 3, imagem 1 %32
    • Close the disc tray, then power off and unplug the Blu-Ray player.
  4. Sony BDP-BX520 Port Board Replacement, Front Panel: passo 4, imagem 1 %32
    • Insert the nylon or metal spudger under the clip on the side near the front of the device. Lift the clip so it is free from the device.
    • Lifting these clips may require you to hold one clip open while you move on to the next clip.
  5. Sony BDP-BX520 Port Board Replacement: passo 5, imagem 1 %32
    • Flip device over so the bottom faces you.
    • Insert the nylon or metal spudger and lift the two clips on the bottom of the device.
  6. Sony BDP-BX520 Port Board Replacement: passo 6, imagem 1 %32
    • Lift the clip on the opposite side of the device with the nylon or metal spudger.
  7. Sony BDP-BX520 Port Board Replacement: passo 7, imagem 1 %32 Sony BDP-BX520 Port Board Replacement: passo 7, imagem 2 %32
    • Grasp the front case firmly and lift from the rest of the device.
    • Lifting may require some force.
  8. Sony BDP-BX520 Port Board Replacement, Port Board: passo 8, imagem 1 %32 Sony BDP-BX520 Port Board Replacement, Port Board: passo 8, imagem 2 %32
    • When handling circuit boards like the motherboard and port board, make sure to only touch them on the sides.
    • Locate the large ribbon cable connecting the port board to the motherboard.
    • Detach the cable from the motherboard by carefully pulling upward on the cable.
  9. Sony BDP-BX520 Port Board Replacement: passo 9, imagem 1 %32
    • Using the Phillips #2 screwdriver, unscrew the silver, 8mm screw holding the board in place.
  10. Sony BDP-BX520 Port Board Replacement: passo 10, imagem 1 %32 Sony BDP-BX520 Port Board Replacement: passo 10, imagem 2 %32
    • Using the nylon or metal spudger, carefully unclip the port board from the side of the player.
  11. Sony BDP-BX520 Port Board Replacement: passo 11, imagem 1 %32
    • Carefully pull the port board free from the Blu-Ray player.
Conclusão
Uma outra pessoa concluiu este guia.
Collier
Membro desde: 01/31/15
352 Reputação
Autoria de 3 guias
Equipe
Cal Poly, Team 8-41, Amido Winter 2015 Membro de Cal Poly, Team 8-41, Amido Winter 2015
CPSU-AMIDO-W15S8G41
Membros da 4
Autoria de 8 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Duração total: 329
