O que você precisa
Plug in the Blu-Ray player, then press the power button, making sure the Blu-Ray player is powered on.
Press the eject button on either the top of the Blu-Ray player or on the remote to open the disc tray.
Locate the three 8 mm screws on the back of the Blu-Ray player.
Using the Phillips #2 screwdriver, unscrew each of the screws and set them aside.
Insert the nylon or metal spudger under the clip on the side near the front of the device. Lift the clip so it is free from the device.
Using a Phillips #2 screwdriver, remove the two silver 8 mm screws on the right side of the disk tray .
6 outras pessoas executaram este guia.
2 comentários
Thanks, this helped a lot. I still cant get the DVD drawer to eject with the eject button. The power light will not turn off.
Thank you thank you thank you. I spent an hour on the phone with Sony “technical support “ and was told nothing could be done except to send it off for servicing. This worked PERFECTLY!!!! THANKS AGAIN ?
