Ir para o conteúdo principal
Sony Alpha a7S II Motherboard Replacement
O que você precisa
  1. Sony Alpha a7S II Motherboard Replacement, Motherboard: passo 1, imagem 1 %32 Sony Alpha a7S II Motherboard Replacement, Motherboard: passo 1, imagem 2 %32
    • Remove the six 4mm screws located at the bottom of the camera using Philips #000 (Circled in red).
    • Remove the two 3mm screws remaining on the base plate using Philips #000 (Circled in orange).
    • Remove the base plate.
  2. Sony Alpha a7S II Motherboard Replacement: passo 2, imagem 1 %32 Sony Alpha a7S II Motherboard Replacement: passo 2, imagem 2 %32 Sony Alpha a7S II Motherboard Replacement: passo 2, imagem 3 %32
    • Use the Philips #000 to remove the two 4mm screws located inside the battery holder.
    • Next, remove the two 4mm screws using the Philips #000 located on left side of the camera.
    • Remove one 4mm screw on the right side of the camera using Philips #000.
  3. Sony Alpha a7S II Motherboard Replacement: passo 3, imagem 1 %32
    • Remove the two 3mm screws from the underneath the LCD screen.
    • Remove the screen.
  4. Sony Alpha a7S II Motherboard Replacement: passo 4, imagem 1 %32 Sony Alpha a7S II Motherboard Replacement: passo 4, imagem 2 %32
    • Remove the rubber viewfinder cap by sliding it upwards.
    • Remove the four 3mm screws behind the cap.
  5. Sony Alpha a7S II Motherboard Replacement: passo 5, imagem 1 %32 Sony Alpha a7S II Motherboard Replacement: passo 5, imagem 2 %32
    • Remove the outer case.
    • Unhook the component outlined by the red square.
    • Next, unscrew the two 4mm screws circled in orange using the Philips #000.
    • Remove the button outlined with the yellow square.
  6. Sony Alpha a7S II Motherboard Replacement: passo 6, imagem 1 %32 Sony Alpha a7S II Motherboard Replacement: passo 6, imagem 2 %32
    • Use a Phillips #000 screwdriver to remove the 4 mm screw from the housing.
    • The access door on the side of the camera must be open to reach the screw and remove the copper plate.
  7. Sony Alpha a7S II Motherboard Replacement: passo 7, imagem 1 %32 Sony Alpha a7S II Motherboard Replacement: passo 7, imagem 2 %32 Sony Alpha a7S II Motherboard Replacement: passo 7, imagem 3 %32
    • Gently pull the clip up on the wire ribbon ports.
    • Using the tweezers, gently pull the wire ribbons out of the ports.
    • Once the ribbon cables are disconnected, the motherboard can be removed.
Conclusão
Alicia Alanis-Angeles
Membro desde: 04/12/22
145 Reputação
Autoria de 1 guia
Equipe
IUPUI, Team 1-5, Beck Spring 2022 Membro de IUPUI, Team 1-5, Beck Spring 2022
IUPUI-BECK-S22S1G5
Membros da 4
1 Guia de autoria
2 comentários
Where can I order the motherboard for this camera?
Joshua Davis - Responder
You can find replacement parts on Aliexpress.
Lou Bariller -
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 23
Últimos 30 dias: 76
Duração total: 1,802
