Ir para o conteúdo principal
Sony Alpha SLT-A55V Battery Replacement
O que você precisa
  1. Sony Alpha SLT-A55V Battery Replacement, Battery: passo 1, imagem 1 %32
    • Locate the battery compartment on the bottom of the unit. Then, slide the latch down to open the cover.
    Pergunte ao FixBot
  2. Sony Alpha SLT-A55V Battery Replacement: passo 2, imagem 1 %32
    • Insert the new battery and close the compartment.
    • Most new lithium batteries are partially charged to improve shelf life. It is recommended to charge the battery after installation even if the indicator shows a full charge. Unlike nickel cadmium batteries, lithium batteries will provide better performance when charged to full capacity from a partial charge of 60%.
    Pergunte ao FixBot
Conclusão
There you go, now you have a fully functional camera again. Do not forget to recharge the other battery to be prepared to repeat this guide.
Equipe
IUPUI, Team 1-1, Wilson Fall 2015 Membro de IUPUI, Team 1-1, Wilson Fall 2015
IUPUI-WILSON-F15S1G1
4 Membros
Autoria de 6 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 3
Últimos 7 dias: 10
Últimos 30 dias: 70
Ao todo: 2,181
