Ir para o conteúdo principal
Sony Alpha NEX-C3 Control Wheel Replacement
O que você precisa
  1. Sony Alpha NEX-C3 Control Wheel Replacement, Top Panel: passo 1, imagem 1 %32
    • Turn the camera off by sliding the power switch.
  2. Sony Alpha NEX-C3 Control Wheel Replacement: passo 2, imagem 1 %32
    • Use a Phillips head 000 screwdriver to remove the 4.0mm screw inside the USB port.
  3. Sony Alpha NEX-C3 Control Wheel Replacement: passo 3, imagem 1 %32
    • Use a Phillips head 000 screwdriver to remove the one 4.0mm screw on the side opposite of the USB port near the shutter button.
  4. Sony Alpha NEX-C3 Control Wheel Replacement: passo 4, imagem 1 %32 Sony Alpha NEX-C3 Control Wheel Replacement: passo 4, imagem 2 %32
    • Open the flap at the top of the camera.
    • Use a Phillips head 000 screwdriver to remove the two 4.0mm screws inside.
  5. Sony Alpha NEX-C3 Control Wheel Replacement: passo 5, imagem 1 %32
    • Gently lift off the top panel with your hands.
  6. Sony Alpha NEX-C3 Control Wheel Replacement, Back Panel: passo 6, imagem 1 %32
    • Use a Phillips head 000 screwdriver to remove the 4.0mm screw at the side opposite of the USB port.
  7. Sony Alpha NEX-C3 Control Wheel Replacement: passo 7, imagem 1 %32 Sony Alpha NEX-C3 Control Wheel Replacement: passo 7, imagem 2 %32
    • Use a Phillips head 000 screwdriver to remove the three 4.0mm screws on the bottom of the camera.
  8. Sony Alpha NEX-C3 Control Wheel Replacement: passo 8, imagem 1 %32
    • Tilt up the LCD screen.
    • Use a Phillips head 000 screwdriver to remove the two coarse 4.0mm screws near the bottom of the camera.
  9. Sony Alpha NEX-C3 Control Wheel Replacement: passo 9, imagem 1 %32
    • Gently pry off the back panel, by wiggling it around the LCD screen.
  10. Sony Alpha NEX-C3 Control Wheel Replacement, Control Wheel: passo 10, imagem 1 %32 Sony Alpha NEX-C3 Control Wheel Replacement, Control Wheel: passo 10, imagem 2 %32
    • Grab the silver plate, and gently pry it up.
  11. Sony Alpha NEX-C3 Control Wheel Replacement: passo 11, imagem 1 %32 Sony Alpha NEX-C3 Control Wheel Replacement: passo 11, imagem 2 %32
    • Gently pinch blue ribbon cable, and pull it out of the port.
Conclusão
3 outras pessoas executaram este guia.
Jonathan Chen
Membro desde: 10/17/17
675 Reputação
Autoria de 6 guias
Equipe
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 25
Duração total: 2,960
