Ir para o conteúdo principal
Sony Alpha NEX-6 Lens-release Button Replacement
O que você precisa
  1. Sony Alpha NEX-6 Lens-release Button Replacement, Finding the Release Button: passo 1, imagem 1 %32
    • Turn the camera with the lens facing up.
    • Find the lens release button - located along the side of the silver lens mount.
  2. Sony Alpha NEX-6 Lens-release Button Replacement, Removing the Lens: passo 2, imagem 1 %32 Sony Alpha NEX-6 Lens-release Button Replacement, Removing the Lens: passo 2, imagem 2 %32
    • Press and hold the lens release button while rotating the lens counterclockwise.
    • Lift the lens when it is no longer attached to the camera.
    • To replace the lens, align the white dot on the lens with the white dot located on the silver lens mount. (See image two)
    • Insert the lens and rotate it clockwise until it is locked in place.
  3. Sony Alpha NEX-6 Lens-release Button Replacement, Lens Mount: passo 3, imagem 1 %32
    • While dealing with this guide, do not touch the delicate image sensor (the center rectangle encircled by the lens mount).
    • After removing the lens, you will come into contact with the lens mount. Start by unscrewing the four 3.5 mm Phillips #00 screws.
    • The outer lens mount ring can now be removed.
  4. Sony Alpha NEX-6 Lens-release Button Replacement: passo 4, imagem 1 %32 Sony Alpha NEX-6 Lens-release Button Replacement: passo 4, imagem 2 %32 Sony Alpha NEX-6 Lens-release Button Replacement: passo 4, imagem 3 %32
    • Pay attention to the positioning of the spacer rings for reassembly.
    • For the first (black) spacer ring, use the tweezers to gently pry the ring out of place.
    • Repeat this step for the second (silver) spacer ring.
    • The third image is what the camera should look like after all spacer rings are removed.
  5. Sony Alpha NEX-6 Lens-release Button Replacement: passo 5, imagem 1 %32 Sony Alpha NEX-6 Lens-release Button Replacement: passo 5, imagem 2 %32
    • To remove the inner lens mount ring, remove the two silver 2.0 mm Phillips #00 screws. This will complete the removal of the lens mount.
  6. Sony Alpha NEX-6 Lens-release Button Replacement, Lens-release Button: passo 6, imagem 1 %32
    • By using tweezers, carefully remove the lens-release button by lifting upward.
Conclusão
Clayton Dale
Membro desde: 01/20/15
1.040 Reputação
Autoria de 7 guias
Equipe
USF Tampa, Team 11-2, Blackwell Winter 2015 Membro de USF Tampa, Team 11-2, Blackwell Winter 2015
USFT-BLACKWELL-W15S11G2
Membros da 4
Autoria de 14 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 10
Duração total: 1,145
