Introdução
Prior to replacing the lens-release button, the lens and the lens mount must first be removed. Following this, the button may be swiftly removed.
O que você precisa
Turn the camera with the lens facing up.
Find the lens release button - located along the side of the silver lens mount.
Press and hold the lens release button while rotating the lens counterclockwise.
Lift the lens when it is no longer attached to the camera.
After removing the lens, you will come into contact with the lens mount. Start by unscrewing the four 3.5 mm Phillips #00 screws.
The outer lens mount ring can now be removed.
For the first (black) spacer ring, use the tweezers to gently pry the ring out of place.
Repeat this step for the second (silver) spacer ring.
The third image is what the camera should look like after all spacer rings are removed.
By using tweezers, carefully remove the lens-release button by lifting upward.
