Ir para o conteúdo principal
Sony Alpha NEX-6 Lens Replacement
  1. Sony Alpha NEX-6 Lens Replacement, Finding the Release Button: passo 1, imagem 1 %32
    • Turn the camera with the lens facing up.
    • Find the lens release button - located along the side of the silver lens mount.
  2. Sony Alpha NEX-6 Lens Replacement, Removing the Lens: passo 2, imagem 1 %32 Sony Alpha NEX-6 Lens Replacement, Removing the Lens: passo 2, imagem 2 %32
    • Press and hold the lens release button while rotating the lens counterclockwise.
    • Lift the lens when it is no longer attached to the camera.
    • To replace the lens, align the white dot on the lens with the white dot located on the silver lens mount. (See image two)
    • Insert the lens and rotate it clockwise until it is locked in place.
Conclusão
The procedure to disassemble this lens is different from reassembly. This guide encompasses both processes.
Clayton Dale
Membro desde: 01/20/15
1.040 Reputação
Autoria de 7 guias
Equipe
USF Tampa, Team 11-2, Blackwell Winter 2015 Membro de USF Tampa, Team 11-2, Blackwell Winter 2015
USFT-BLACKWELL-W15S11G2
Membros da 4
Autoria de 14 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 2
Últimos 30 dias: 14
Duração total: 2,463
