Ir para o conteúdo principal
Sony Alpha NEX-6 Battery Replacement
O que você precisa
  1. Sony Alpha NEX-6 Battery Replacement, Battery: passo 1, imagem 1 %32
    • Prior to operating on this device, be sure the camera is turned OFF. With power, the camera can be a dangerous device to work with.
    • Turn the camera off by switching the power knob "OFF" text to the white selector dot.
  2. Sony Alpha NEX-6 Battery Replacement: passo 2, imagem 1 %32
    • Flip the camera upside-down and carefully place it on a flat surface.
    • With the lens facing outward, locate the battery compartment - indicated by a grooved latch.
    • Push the latch to the right to unlock the battery compartment. The door should flip upward.
  3. Sony Alpha NEX-6 Battery Replacement: passo 3, imagem 1 %32
    • With the compartment open, locate a blue tab shown with spudger
    • Press the tab to the side (to the left, or toward the camera wall). This will eject the camera battery.
Conclusão
Clayton Dale
Membro desde: 01/20/15
1.040 Reputação
Autoria de 7 guias
Equipe
USF Tampa, Team 11-2, Blackwell Winter 2015 Membro de USF Tampa, Team 11-2, Blackwell Winter 2015
USFT-BLACKWELL-W15S11G2
Membros da 4
Autoria de 14 guias
3 comentários
Will not spring out. Any ideas?
rustychinnis - Responder
Got it, battery damaged. Tapped on edge to remove battery
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 11
Duração total: 2,274
