Ir para o conteúdo principal
Sony Alpha NEX-5N E-mount Replacement
O que você precisa
  1. Sony Alpha NEX-5N E-mount Replacement, E-mount: passo 1, imagem 1 %32 Sony Alpha NEX-5N E-mount Replacement, E-mount: passo 1, imagem 2 %32
    • While completing this guide, do not touch the image sensor (the center rectangle encircled by the lens mount).
    • Unscrew the 4 silver 1.2 mm Phillips #000 screws along the front outer lens mount.
    • Applying extra force to unscrew these 4 screws may be necessary.
    • Detach the outer lens mount ring.
  2. Sony Alpha NEX-5N E-mount Replacement: passo 2, imagem 1 %32 Sony Alpha NEX-5N E-mount Replacement: passo 2, imagem 2 %32
    • Pay attention to the positioning and order of the spacing rings for reassembly.
    • Using your fingers, pull out the first black spacer ring.
    • Repeat the previous step for the second silver spacer ring.
  3. Sony Alpha NEX-5N E-mount Replacement: passo 3, imagem 1 %32 Sony Alpha NEX-5N E-mount Replacement: passo 3, imagem 2 %32 Sony Alpha NEX-5N E-mount Replacement: passo 3, imagem 3 %32
    • Unscrew the 2 silver 1.2 mm Phillips #000 screws on opposing sides in the lens ring area.
    • Using your fingers, easily pull off lens housing. This will complete the removal of the E-mount.
    • The lens release button and the small spring underneath will be loose.
Conclusão
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 12
Duração total: 1,238
