Ir para o conteúdo principal
Sony Alpha NEX-5N Battery Replacement
  1. Sony Alpha NEX-5N Battery Replacement, Battery: passo 1, imagem 1 %32
    • Before operating on this device, be sure the device is turned off.
    • Turn the device off by switching the power knob to face the word "OFF".
  2. Sony Alpha NEX-5N Battery Replacement: passo 2, imagem 1 %32 Sony Alpha NEX-5N Battery Replacement: passo 2, imagem 2 %32
    • Flip the device upside-down and gently place it down on a flat surface.
    • Locate the battery compartment, which is indicated by a grooved latch.
    • Push the latch to the right so that the arrow is positioned above the word "Open". The door should then flip upward.
  3. Sony Alpha NEX-5N Battery Replacement: passo 3, imagem 1 %32 Sony Alpha NEX-5N Battery Replacement: passo 3, imagem 2 %32
    • With the battery compartment latch open, locate the lock lever.
    • Press the lock lever to the left. This will eject the camera battery.
Conclusão
Demi Deletang
Membro desde: 09/28/15
101 Reputação
Autoria de 1 guia
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 11
Últimos 30 dias: 51
Duração total: 2,456
