Ir para o conteúdo principal
Sony Alpha NEX-3N Mainboard Replacement
O que você precisa
  1. Sony Alpha NEX-3N Mainboard Replacement, Getting Started: passo 1, imagem 1 %32 Sony Alpha NEX-3N Mainboard Replacement, Getting Started: passo 1, imagem 2 %32
    • Remove battery and card
  2. Sony Alpha NEX-3N Mainboard Replacement, Back Case 1: passo 2, imagem 1 %32 Sony Alpha NEX-3N Mainboard Replacement, Back Case 1: passo 2, imagem 2 %32 Sony Alpha NEX-3N Mainboard Replacement, Back Case 1: passo 2, imagem 3 %32
    • Right side, remove 1 M1.4x3.7 screw
    • Left side, remove 3 M1.4x3.7 screws
    • Bottom side, remove 5 M1.4x3.7 screws, including 2 in battery bay. 2 of them out of this photo, you can find them.
    • Do NOT touch screws on the bottom of LCD assembly.
  3. Sony Alpha NEX-3N Mainboard Replacement, Back Case 2: passo 3, imagem 1 %32
    • Pop the flash.
    • In flash room, remove 1 (one) M1.4x3.8 black screw.
  4. Sony Alpha NEX-3N Mainboard Replacement, Back Case 3: passo 4, imagem 1 %32 Sony Alpha NEX-3N Mainboard Replacement, Back Case 3: passo 4, imagem 2 %32 Sony Alpha NEX-3N Mainboard Replacement, Back Case 3: passo 4, imagem 3 %32
    • Remove LCD hinge cover, by sliding to the left.
    • Remove back cover, actually just a plastic frame.
  5. Sony Alpha NEX-3N Mainboard Replacement, LCD assembly: passo 5, imagem 1 %32 Sony Alpha NEX-3N Mainboard Replacement, LCD assembly: passo 5, imagem 2 %32
    • Remove 1 M1.4x2 screw
    • Remove another M1.4x2 screw, sorry for the angle.
  6. Sony Alpha NEX-3N Mainboard Replacement, LCD Assembly: passo 6, imagem 1 %32 Sony Alpha NEX-3N Mainboard Replacement, LCD Assembly: passo 6, imagem 2 %32 Sony Alpha NEX-3N Mainboard Replacement, LCD Assembly: passo 6, imagem 3 %32
    • CAUTION. Sony makes world's MOST BRITTLE FPC!
    • Loosen LCD assemble with caution!
    • Release FPC cable, the connector is flip type.
  7. Sony Alpha NEX-3N Mainboard Replacement, The LCD assembly: passo 7, imagem 1 %32
    • The LCD assembly
  8. Sony Alpha NEX-3N Mainboard Replacement, Keypad: passo 8, imagem 1 %32 Sony Alpha NEX-3N Mainboard Replacement, Keypad: passo 8, imagem 2 %32 Sony Alpha NEX-3N Mainboard Replacement, Keypad: passo 8, imagem 3 %32
    • Lift the keypad.
    • Detach FPC
  9. Sony Alpha NEX-3N Mainboard Replacement, Screws: passo 9, imagem 1 %32
    • Remove 3 M1.4x3.6 black screws, 2 of them out of focus
  10. Sony Alpha NEX-3N Mainboard Replacement: passo 10, imagem 1 %32 Sony Alpha NEX-3N Mainboard Replacement: passo 10, imagem 2 %32
    • Slide the flash assembly backwards with caution.
    • Detach flash FPC by pulling it out of the socket.
    • High Voltage! Do NOT touch metal on FPC.
    • Then remove the flash assembly.
  11. Sony Alpha NEX-3N Mainboard Replacement: passo 11, imagem 1 %32
    • Remove that part whatever called, by sliding it backwards.
  12. Sony Alpha NEX-3N Mainboard Replacement, Screws: passo 12, imagem 1 %32 Sony Alpha NEX-3N Mainboard Replacement, Screws: passo 12, imagem 2 %32 Sony Alpha NEX-3N Mainboard Replacement, Screws: passo 12, imagem 3 %32
    • 1 ST1.7x5
    • 2 ST1.7x5
    • 1 M1.4x3.6 black
  13. Sony Alpha NEX-3N Mainboard Replacement, The Grip: passo 13, imagem 1 %32 Sony Alpha NEX-3N Mainboard Replacement, The Grip: passo 13, imagem 2 %32
    • Remove 2 ST1.7x5 screws from inside the battery bay. (one of them not shown, deeper inside) insert screw driver through a hole in the shielding cover.
    • Pop the grip off. From back, push to the right, then it flies forward.
  14. Sony Alpha NEX-3N Mainboard Replacement, More Screws: passo 14, imagem 1 %32
    • Remove 2 M1.4x2 black screws
  15. Sony Alpha NEX-3N Mainboard Replacement, Pop the Shielding Cover: passo 15, imagem 1 %32 Sony Alpha NEX-3N Mainboard Replacement, Pop the Shielding Cover: passo 15, imagem 2 %32
    • with caution and patient.
  16. Sony Alpha NEX-3N Mainboard Replacement, One More Shield: passo 16, imagem 1 %32 Sony Alpha NEX-3N Mainboard Replacement, One More Shield: passo 16, imagem 2 %32 Sony Alpha NEX-3N Mainboard Replacement, One More Shield: passo 16, imagem 3 %32
    • 1 M1.4x3.6
  17. Sony Alpha NEX-3N Mainboard Replacement, Detach 7000 FPCs: passo 17, imagem 1 %32
    • Sensor power, flip
    • Sensor signal, flip
    • Shutter, pull
    • Lens contacts, pull. Did I mention that Sony makes world's most brittle FPC?
    • Whatever, pull
    • Whatever, pull
    • Shutter charger motor FPC, (backside, pull out)
  18. Sony Alpha NEX-3N Mainboard Replacement: passo 18, imagem 1 %32
    • Flip the Mainboard up
    • Pull out one more FPC
    • Discharge then desolder 4 wires.
    • CAUTION! Possible high DC voltage >300V
  19. Sony Alpha NEX-3N Mainboard Replacement: passo 19, imagem 1 %32
    • Lift main board and plastic frame with flash capacitor.
Conclusão
Terrance
Membro desde: 11/17/09
6.359 Reputação
Autoria de 17 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 1
Últimos 30 dias: 4
Duração total: 55
