Ir para o conteúdo principal
Sony Alpha ILCE-6000 Lens Replacement
O que você precisa
  1. Sony Alpha ILCE-6000 Lens Replacement, Lens: passo 1, imagem 1 %32
    • Turn of camera by turning the switch to OFF.
  2. Sony Alpha ILCE-6000 Lens Replacement: passo 2, imagem 1 %32
    • Use the finger, press and hold the release black circle button ( on the bottom ) next to the lens on the front of the camera.
  3. Sony Alpha ILCE-6000 Lens Replacement: passo 3, imagem 1 %32 Sony Alpha ILCE-6000 Lens Replacement: passo 3, imagem 2 %32
    • Using the left hand or the right hand to hold the camera body, other hand twist the lens counterclockwise and pull it off.
    • Align the white dot of the lens to the white dot on the camera mount to completely replace.
Conclusão
Vuong Nguyen
Membro desde: 02/02/17
122 Reputação
Autoria de 1 guia
Equipe
UW Tacoma, Team 1-4, Rose Winter 2017 Membro de UW Tacoma, Team 1-4, Rose Winter 2017
UWT-ROSE-W17S1G4
Membros da 4
Autoria de 10 guias
Um comentário
my camera will not recognize my lens, optical steady shot 1650. it used to work fine, but I dropped it. now the camera says it's not attached properly. any suggestions?
Connie - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 6
Últimos 30 dias: 32
Duração total: 1,960
