Ir para o conteúdo principal
Sony Alpha ILCE-6000 E-mount Replacement
O que você precisa
  1. Sony Alpha ILCE-6000 E-mount Replacement, Lens: passo 1, imagem 1 %32
    • Turn of camera by turning the switch to OFF.
  2. Sony Alpha ILCE-6000 E-mount Replacement: passo 2, imagem 1 %32
    • Use the finger, press and hold the release black circle button ( on the bottom ) next to the lens on the front of the camera.
  3. Sony Alpha ILCE-6000 E-mount Replacement: passo 3, imagem 1 %32 Sony Alpha ILCE-6000 E-mount Replacement: passo 3, imagem 2 %32
    • Using the left hand or the right hand to hold the camera body, other hand twist the lens counterclockwise and pull it off.
    • Align the white dot of the lens to the white dot on the camera mount to completely replace.
  4. Sony Alpha ILCE-6000 E-mount Replacement, E-mount Replacement: passo 4, imagem 1 %32 Sony Alpha ILCE-6000 E-mount Replacement, E-mount Replacement: passo 4, imagem 2 %32
    • Locate the E-mount on the front of the camera
  5. Sony Alpha ILCE-6000 E-mount Replacement: passo 5, imagem 1 %32 Sony Alpha ILCE-6000 E-mount Replacement: passo 5, imagem 2 %32 Sony Alpha ILCE-6000 E-mount Replacement: passo 5, imagem 3 %32
    • Take a Philips head 00 screw to remove the four of the 5.1mm screws located on the E-mount.
  6. Sony Alpha ILCE-6000 E-mount Replacement: passo 6, imagem 1 %32 Sony Alpha ILCE-6000 E-mount Replacement: passo 6, imagem 2 %32 Sony Alpha ILCE-6000 E-mount Replacement: passo 6, imagem 3 %32
    • After removing the screws, pull off the E-mount metal ring gently and wiggle it until its free.
    • Remove the plastic ring located under the metal ring.
    • Do not remove the metal piece that is located behind the plastic ring.
  7. Sony Alpha ILCE-6000 E-mount Replacement: passo 7, imagem 1 %32
    • Replace the plastic E-mount ring with a new one.
Conclusão
Yirga Yilma
Membro desde: 02/02/17
221 Reputação
Autoria de 2 guias
Equipe
UW Tacoma, Team 1-4, Rose Winter 2017 Membro de UW Tacoma, Team 1-4, Rose Winter 2017
UWT-ROSE-W17S1G4
Membros da 4
Autoria de 10 guias
2 comentários
Hello folks,
actually I have to replace the E-mount ring my ILCE-6000, which seems very easy with this description. Thanks a lot for this!
Is the ring available anywhere on this globe? I would truly appreciate any hint.
Best regards, JDK
JDK - Responder
Hi there, found a source for the ring as original part. The price is reasonable. Now waiting for delivery ...
Best regards, JDK
JDK - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 10
Últimos 30 dias: 43
Duração total: 3,324
