Ir para o conteúdo principal
Sony Alpha DSLR- A850 Viewfinder Window Replacement
O que você precisa
  1. Sony Alpha DSLR- A850 Viewfinder Window Replacement, Viewfinder Cover: passo 1, imagem 1 %32
    • Find the rubber viewfinder cover on the upper rear of the camera, above the view screen.
  2. Sony Alpha DSLR- A850 Viewfinder Window Replacement: passo 2, imagem 1 %32
    • Slide the rubber piece off.
    • There may be a slight popping sound.
  3. Sony Alpha DSLR- A850 Viewfinder Window Replacement: passo 3, imagem 1 %32
    • Once the rubber piece has been removed, inspect the area.
    • If everything looks fine, go ahead and slide the new rubber piece on the same way the old piece was slipped off.
  4. Sony Alpha DSLR- A850 Viewfinder Window Replacement, Viewfinder Window: passo 4, imagem 1 %32 Sony Alpha DSLR- A850 Viewfinder Window Replacement, Viewfinder Window: passo 4, imagem 2 %32
    • Remove all four screws from the viewfinder.
  5. Sony Alpha DSLR- A850 Viewfinder Window Replacement: passo 5, imagem 1 %32 Sony Alpha DSLR- A850 Viewfinder Window Replacement: passo 5, imagem 2 %32
    • Grasp the side of the window with either a set of tweezers or your fingers. Lift upwards and slightly towards the base of the camera.
  6. Sony Alpha DSLR- A850 Viewfinder Window Replacement: passo 6, imagem 1 %32
    • To reinsert the window, push inward and slightly forward. There is a tab on the camera that the window must catch on in order to be put into place.
Conclusão
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 5
Duração total: 384
