Ir para o conteúdo principal
Sony Alpha DSLR- A850 Focus lens Replacement
O que você precisa
  1. Sony Alpha DSLR- A850 Focus lens Replacement, Focus lens: passo 1, imagem 1 %32 Sony Alpha DSLR- A850 Focus lens Replacement, Focus lens: passo 1, imagem 2 %32 Sony Alpha DSLR- A850 Focus lens Replacement, Focus lens: passo 1, imagem 3 %32
    • Push in the button next to the lens.
    • While holding the button twist the lens counter-clockwise.
    • Pull up and remove lens from camera.
  2. Sony Alpha DSLR- A850 Focus lens Replacement: passo 2, imagem 1 %32 Sony Alpha DSLR- A850 Focus lens Replacement: passo 2, imagem 2 %32 Sony Alpha DSLR- A850 Focus lens Replacement: passo 2, imagem 3 %32
    • Inside toward the top you will find a small slit in the plastic piece.
    • Insert a flat head screw driver into the slit and pull down to access the focus lens.
  3. Sony Alpha DSLR- A850 Focus lens Replacement: passo 3, imagem 1 %32 Sony Alpha DSLR- A850 Focus lens Replacement: passo 3, imagem 2 %32 Sony Alpha DSLR- A850 Focus lens Replacement: passo 3, imagem 3 %32
    Ferramenta utilizada nesse passo:
    Comprar
    • Using tweezers grab the focus lens on the side by the two tabs that are on it.
    • Do not grab the focus lens in the middle as this will damage the lens.
    • Pull out and remove focus lens from camera.
  4. Sony Alpha DSLR- A850 Focus lens Replacement: passo 4, imagem 1 %32 Sony Alpha DSLR- A850 Focus lens Replacement: passo 4, imagem 2 %32 Sony Alpha DSLR- A850 Focus lens Replacement: passo 4, imagem 3 %32
    • When inserting new focus make sure to orient it where the two tabs are facing towards you with the smaller tab facing up.
    • Angle the focus lens to make installation easier.
    • Lay the new focus lens into the plastic tray.
    • It does not snap into place.
  5. Sony Alpha DSLR- A850 Focus lens Replacement: passo 5, imagem 1 %32 Sony Alpha DSLR- A850 Focus lens Replacement: passo 5, imagem 2 %32
    • Insert screw driver into the slit and push up to close.
    • You can also use your thumb, if you are careful not to touch the lens as this could leave a smudge on the lens.
    • You will hear a click when the plastic tray is back in place.
  6. Sony Alpha DSLR- A850 Focus lens Replacement: passo 6, imagem 1 %32 Sony Alpha DSLR- A850 Focus lens Replacement: passo 6, imagem 2 %32
    • When re-installing the lens line up the orange dots that are one both lens and camera.
    • Fit lens into place and turn clockwise to secure it back to camera.
Conclusão
You have now completed a focus lens replacement.
Walter Littlefield
Membro desde: 03/21/18
265 Reputação
Autoria de 2 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 12
Duração total: 742
