Ir para o conteúdo principal
Sony Alpha A350 Front Case Replacement
O que você precisa
  1. Sony Alpha A350 Front Case Replacement, Front Case: passo 1, imagem 1 %32 Sony Alpha A350 Front Case Replacement, Front Case: passo 1, imagem 2 %32
    • Using a Phillips #00 Screwdriver, remove the four 5.5mm screws from the bottom of the camera.
    • Using a Phillips #00 Screwdriver, remove the one 4.3mm screw.
  2. Sony Alpha A350 Front Case Replacement: passo 2, imagem 1 %32 Sony Alpha A350 Front Case Replacement: passo 2, imagem 2 %32
    • Using a Phillips #00 screwdriver, remove one 3.6mm screw on the left side of the camera.
    • Open the remote / DC under the rubber flap to reveal a screw.
    • Using the Phillips #00 screwdriver, remove one 4.3mm screw.
  3. Sony Alpha A350 Front Case Replacement: passo 3, imagem 1 %32 Sony Alpha A350 Front Case Replacement: passo 3, imagem 2 %32
    • Open the flash on the top of the camera and remove two 4.3mm screws with a Phillips #00 screwdriver.
    • If the spring guard falls out during deconstruction, gently place the guard over the spring during construction.
    • To open the flash, simply press the button on the left side.
  4. Sony Alpha A350 Front Case Replacement: passo 4, imagem 1 %32 Sony Alpha A350 Front Case Replacement: passo 4, imagem 2 %32
    • Open the plastic SD card door.
    • Using Phillips #00 screwdriver, remove two 4.4 mm screws outside and two 4.4mm screws inside the door.
  5. Sony Alpha A350 Front Case Replacement: passo 5, imagem 1 %32 Sony Alpha A350 Front Case Replacement: passo 5, imagem 2 %32
    • Gently pull the outer front case from the camera.
    • It should fall apart easily if all screws are removed.
Conclusão
Danielle Trivett
Membro desde: 11/04/19
337 Reputação
Autoria de 3 guias
Equipe
IUPUI, Team S1-G6, Henning Fall 2019 Membro de IUPUI, Team S1-G6, Henning Fall 2019
IUPUI-HENNING-F19S1G6
Membros da 3
Autoria de 6 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 2
Últimos 30 dias: 21
Duração total: 726
