Ir para o conteúdo principal
Sony Alpha A3000 shutter button Replacement
O que você precisa
  1. Sony Alpha A3000 shutter button Replacement, Rear Case: passo 1, imagem 1 %32 Sony Alpha A3000 shutter button Replacement, Rear Case: passo 1, imagem 2 %32 Sony Alpha A3000 shutter button Replacement, Rear Case: passo 1, imagem 3 %32
    • Remove the seven highlighted screws shown here.
    • Screws are teeny tiny, don't lose them!
  2. Sony Alpha A3000 shutter button Replacement: passo 2, imagem 1 %32 Sony Alpha A3000 shutter button Replacement: passo 2, imagem 2 %32
    • Remove this final screw from the memory card compartment.
    • Remove the chassis by pulling the back cover away from the camera.
    • Be careful not to damage any of the delicate ribbon cables when removing the chassis.
  3. Sony Alpha A3000 shutter button Replacement: passo 3, imagem 1 %32 Sony Alpha A3000 shutter button Replacement: passo 3, imagem 2 %32
    • Gently but forcefully lift up on the parallel cable connecting the two halves of the camera.
  4. Sony Alpha A3000 shutter button Replacement, Motherboard: passo 4, imagem 1 %32 Sony Alpha A3000 shutter button Replacement, Motherboard: passo 4, imagem 2 %32
    • After removing the backing from the camera. Remove the two final screws in the memory compartment area.
    • Detach the facing for the memory dock.
  5. Sony Alpha A3000 shutter button Replacement: passo 5, imagem 1 %32 Sony Alpha A3000 shutter button Replacement: passo 5, imagem 2 %32
    • Remove the eight screws securing the mount for the flash device.
  6. Sony Alpha A3000 shutter button Replacement: passo 6, imagem 1 %32 Sony Alpha A3000 shutter button Replacement: passo 6, imagem 2 %32
    • Remove the three remaining screws holding in the protective metal casing.
  7. Sony Alpha A3000 shutter button Replacement: passo 7, imagem 1 %32
    • Remove the metal casing.
  8. Sony Alpha A3000 shutter button Replacement: passo 8, imagem 1 %32
    • Remove three screws holding down the motherboard .
  9. Sony Alpha A3000 shutter button Replacement: passo 9, imagem 1 %32 Sony Alpha A3000 shutter button Replacement: passo 9, imagem 2 %32
    • Detach the nine serial cables connecting it to the camera body.
  10. Sony Alpha A3000 shutter button Replacement: passo 10, imagem 1 %32
    • Finally remove the motherboard from the casing.
  11. Sony Alpha A3000 shutter button Replacement, ...: passo 11, imagem 1 %32
    • shutter button placement...
  12. Sony Alpha A3000 shutter button Replacement, Unscrew motherboard frame: passo 12, imagem 1 %32 Sony Alpha A3000 shutter button Replacement, Unscrew motherboard frame: passo 12, imagem 2 %32
    • Remove two screws holding plastic/metal frame.
  13. Sony Alpha A3000 shutter button Replacement, Remove motherboard frame: passo 13, imagem 1 %32 Sony Alpha A3000 shutter button Replacement, Remove motherboard frame: passo 13, imagem 2 %32
    • Holding the battery door gently lift the frame up .
  14. Sony Alpha A3000 shutter button Replacement, Capacitor module: passo 14, imagem 1 %32 Sony Alpha A3000 shutter button Replacement, Capacitor module: passo 14, imagem 2 %32
    • Pull out the capacitor and move the capacitor board (flexible) to the left to clear the way for future steps.
  15. Sony Alpha A3000 shutter button Replacement, Remove buttons module: passo 15, imagem 1 %32 Sony Alpha A3000 shutter button Replacement, Remove buttons module: passo 15, imagem 2 %32 Sony Alpha A3000 shutter button Replacement, Remove buttons module: passo 15, imagem 3 %32
    • Remove two screws mounting plastic buttons module.
    • Remove the module.
  16. Sony Alpha A3000 shutter button Replacement, Soldering!: passo 16, imagem 1 %32 Sony Alpha A3000 shutter button Replacement, Soldering!: passo 16, imagem 2 %32 Sony Alpha A3000 shutter button Replacement, Soldering!: passo 16, imagem 3 %32
    • Replace the ALPS SKSDPCE010 microswitch. Look out for the correct allignment and orientation (first pin marked with a dot).
Conclusão
Uma outra pessoa concluiu este guia.
Andrzej Majchrzak
Membro desde: 04/26/17
131 Reputação
Autoria de 1 guia
3 comentários
Excellent article, I would like to know what should be done to replace or repair the mode selector of the camera, (Dial mode) I appreciate this great contribution. Greetings.
Edgar Delgado - Responder
Mode selector switch is visible on 2 photos of buttons module PCB. Look for a switch with blue knob on 2nd Photo of step 16. I dont know the serial number or replacement.
Andrzej Majchrzak - Responder
Thank you so much for reply.
Edgar Delgado -
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 3
Últimos 30 dias: 15
Duração total: 2,382
