Ir para o conteúdo principal
Sony Alpha A3000 Motherboard Replacement
O que você precisa
  1. Sony Alpha A3000 Motherboard Replacement, Rear Case: passo 1, imagem 1 %32 Sony Alpha A3000 Motherboard Replacement, Rear Case: passo 1, imagem 2 %32 Sony Alpha A3000 Motherboard Replacement, Rear Case: passo 1, imagem 3 %32
    • Remove the seven highlighted screws shown here.
    • Screws are teeny tiny, don't lose them!
  2. Sony Alpha A3000 Motherboard Replacement: passo 2, imagem 1 %32 Sony Alpha A3000 Motherboard Replacement: passo 2, imagem 2 %32
    • Remove this final screw from the memory card compartment.
    • Remove the chassis by pulling the back cover away from the camera.
    • Be careful not to damage any of the delicate ribbon cables when removing the chassis.
  3. Sony Alpha A3000 Motherboard Replacement: passo 3, imagem 1 %32 Sony Alpha A3000 Motherboard Replacement: passo 3, imagem 2 %32
    • Gently but forcefully lift up on the parallel cable connecting the two halves of the camera.
  4. Sony Alpha A3000 Motherboard Replacement, Motherboard: passo 4, imagem 1 %32 Sony Alpha A3000 Motherboard Replacement, Motherboard: passo 4, imagem 2 %32
    • After removing the backing from the camera. Remove the two final screws in the memory compartment area.
    • Detach the facing for the memory dock.
  5. Sony Alpha A3000 Motherboard Replacement: passo 5, imagem 1 %32 Sony Alpha A3000 Motherboard Replacement: passo 5, imagem 2 %32
    • Remove the eight screws securing the mount for the flash device.
  6. Sony Alpha A3000 Motherboard Replacement: passo 6, imagem 1 %32 Sony Alpha A3000 Motherboard Replacement: passo 6, imagem 2 %32
    • Remove the three remaining screws holding in the protective metal casing.
  7. Sony Alpha A3000 Motherboard Replacement: passo 7, imagem 1 %32
    • Remove the metal casing.
  8. Sony Alpha A3000 Motherboard Replacement: passo 8, imagem 1 %32
    • Remove three screws holding down the motherboard .
  9. Sony Alpha A3000 Motherboard Replacement: passo 9, imagem 1 %32 Sony Alpha A3000 Motherboard Replacement: passo 9, imagem 2 %32
    • Detach the nine serial cables connecting it to the camera body.
  10. Sony Alpha A3000 Motherboard Replacement: passo 10, imagem 1 %32
    • Finally remove the motherboard from the casing.
Conclusão
6 outras pessoas executaram este guia.
Leonard Holloman
Membro desde: 08/31/15
638 Reputação
Autoria de 4 guias
Equipe
USF Tampa, Team 4-4, Meier Fall 2015 Membro de USF Tampa, Team 4-4, Meier Fall 2015
USFT-MEIER-F15S4G4
Membros da 4
Autoria de 10 guias
Um comentário
Then loose the plug all the motherboard?
kongre172 - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 27
Duração total: 2,263
