Ir para o conteúdo principal
Sony Alpha A3000 Battery Replacement
  1. Sony Alpha A3000 Battery Replacement, Battery: passo 1, imagem 1 %32
    • The battery compartment is located on the bottom of the camera as shown. To access the battery slide the compartment switch from LOCK to OPEN.
    • Before operating on device, ensure that the camera is powered off and the surface of operation is clean and free of dirt or other obstructions.
  2. Sony Alpha A3000 Battery Replacement: passo 2, imagem 1 %32
    • Push back the blue tab releasing the battery which should spring forth on its own.
  3. Sony Alpha A3000 Battery Replacement: passo 3, imagem 1 %32
    • To insert replacement, depress the blue tab again inserting the battery as shown until the blue tab springs back into place. Ensure battery is secure, close the battery compartment and return the latch to the LOCK position.
    • The replacement battery must meet specifications declared by Sony.
Conclusão
Uma outra pessoa concluiu este guia.
Junior Recinos
Membro desde: 08/25/15
227 Reputação
Autoria de 1 guia
Equipe
USF Tampa, Team 4-4, Meier Fall 2015 Membro de USF Tampa, Team 4-4, Meier Fall 2015
USFT-MEIER-F15S4G4
Membros da 4
Autoria de 10 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 1
Últimos 30 dias: 7
Duração total: 2,066
