Ir para o conteúdo principal
Sony Alpha 6000 Setting Wheel Replacement
Guia arquivado
Este guia é mantido exclusivamente para fins históricos. Use a versão atualizada do guia para executar o reparo.
O que você precisa
  1. Sony Alpha 6000 Setting Wheel Replacement, Battery: passo 1, imagem 1 %32
    • Make sure the camera is turned off by turning the switch to OFF.
  2. Sony Alpha 6000 Setting Wheel Replacement: passo 2, imagem 1 %32
    • Flip the camera around to access the battery compartment.
    • Slide the battery compartment lock to the left to unlock it.
  3. Sony Alpha 6000 Setting Wheel Replacement: passo 3, imagem 1 %32
    • Locate the blue latch that holds the battery in.
  4. Sony Alpha 6000 Setting Wheel Replacement: passo 4, imagem 1 %32
    • Push the latch back to release battery.
  5. Sony Alpha 6000 Setting Wheel Replacement: passo 5, imagem 1 %32
    • The battery can now be taken out of its compartment.
  6. Sony Alpha 6000 Setting Wheel Replacement, Back Cover: passo 6, imagem 1 %32
    • Turn the camera upside down and unscrew these two bottom 6 mm screws located on either side of the body by using the J00 head screw.
  7. Sony Alpha 6000 Setting Wheel Replacement: passo 7, imagem 1 %32
    • Turn the camera sideways.
    • Open the mini HDMI compartment and locate the two 6 mm screw underneath and another to the right of the compartment.
    • Unscrew using the J00 head screw.
  8. Sony Alpha 6000 Setting Wheel Replacement: passo 8, imagem 1 %32
    • Locate the two 4 mm screws within the battery compartment and unscrew them using the J00 screw head.
  9. Sony Alpha 6000 Setting Wheel Replacement: passo 9, imagem 1 %32
    • Bend the camera's screen forward to uncover two 3 mm screws below the eyepiece.
    • Locate them and unscrew them.
  10. Sony Alpha 6000 Setting Wheel Replacement: passo 10, imagem 1 %32 Sony Alpha 6000 Setting Wheel Replacement: passo 10, imagem 2 %32
    • Use a plastic opening tool around the body of the camera to wedge the back cover off. Start from the bottom next to the battery compartment.
    • If necessary, lightly use your hand to pull the the back cover down to completely remove it.
  11. Sony Alpha 6000 Setting Wheel Replacement, Setting Wheel: passo 11, imagem 1 %32 Sony Alpha 6000 Setting Wheel Replacement, Setting Wheel: passo 11, imagem 2 %32 Sony Alpha 6000 Setting Wheel Replacement, Setting Wheel: passo 11, imagem 3 %32
    • Once the back cover is removed, using tweezers, pull to remove the ribbon cable that is holding the settings wheel.
    • Now you can pull the settings wheel out of the camera.
Conclusão
To put the camera back together, follow these steps in reverse order.
5 outras pessoas executaram este guia.
Fernando Sierra
Membro desde: 09/30/16
352 Reputação
Autoria de 2 guias
Equipe
USF Tampa, Team 4-5, Passmore Fall 2016 Membro de USF Tampa, Team 4-5, Passmore Fall 2016
USFT-PASSMORE-F16S4G5
Membros da 3
Autoria de 12 guias
2 comentários
I am trying to remove the back so I can remove the USB cover and hing as the cover is broke. If I fallow these instructions will I get to that pin?
Nate - Responder
Quiet nice instructions… but you are missing a few important steps which are necessary to avoid damage:
1) You forget to mention the 3rd screw at the entry of the battery compartment.. in your picture of step 8 it is allready loose. It is not possible to remove the back panel without loosening of that screw.
2) It is much easier to remove the back panel, if you lift up the top panel, therefor you should loosen the two J00 screws under the internal flash.
3) You forget to mention that there needs to be a screw removed at the “dioptre correction wheel”, therefor the central small rubber patch needs to be removed with tweezers, then the underlying J00 can be unscrewed and the “dioptre correction wheel” removed.
4) Once the back panel has then carefully be loosened with a plastic opening tool you should be able to remove an additional screw of the eyepiece (right side), so that the eyepiece cover can be lift off, and then the backpanel is much easier to be removed.
Look for youtube “Dissasembly A6000”!
Torsten S. - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 5
Últimos 7 dias: 27
Últimos 30 dias: 145
Duração total: 9,674
