Ir para o conteúdo principal
Sony Alpha 5100 Lens Replacement
  1. Sony Alpha 5100 Lens Replacement, Lens: passo 1, imagem 1 %32
    • Place the camera in front so the lens is facing you. There should be a small button on the bottom left side of the lens.
  2. Sony Alpha 5100 Lens Replacement: passo 2, imagem 1 %32
    • While holding down the button with your left thumb, use your right hand to twist the lens counterclockwise.
    • Make sure that you are twisting the bottom end of the lens.
  3. Sony Alpha 5100 Lens Replacement: passo 3, imagem 1 %32
    • To insert a new lens, align the marking on the lens to the marking on the mount on the camera body.
    • Once insert correctly, you can twist the lens in clockwise direction easily until it clicks.
Conclusão
Quang Phan
Membro desde: 10/30/19
97 Reputação
Autoria de 1 guia
Equipe
UMass Dartmouth, Team S4-G6, Saloman Fall 2019 Membro de UMass Dartmouth, Team S4-G6, Saloman Fall 2019
UMASSD-SALOMAN-F19S4G6
Membros da 3
Autoria de 8 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 9
Últimos 30 dias: 23
Duração total: 866
