Ir para o conteúdo principal
Sony Alpha 5100 Front Plate Replacement
  1. Sony Alpha 5100 Front Plate Replacement, Battery: passo 1, imagem 1 %32 Sony Alpha 5100 Front Plate Replacement, Battery: passo 1, imagem 2 %32
    • Slide the power switch on the top of the camera to "off."
    • Turn the camera over to the bottom, and push the latch towards the side marked "open" to release the battery cover.
  2. Sony Alpha 5100 Front Plate Replacement: passo 2, imagem 1 %32
    • Push the blue spring-loaded lever to release the battery.
    • Remove the battery from the camera.
  3. Sony Alpha 5100 Front Plate Replacement, Front Plate: passo 3, imagem 1 %32 Sony Alpha 5100 Front Plate Replacement, Front Plate: passo 3, imagem 2 %32 Sony Alpha 5100 Front Plate Replacement, Front Plate: passo 3, imagem 3 %32
    • Remove one 2mm Phillips #00 screw from the flash plate cover.
    • Use the spudger to pop the plate off.
    • Remove two 2mm Phillips #00 screws on the side of the camera.
  4. Sony Alpha 5100 Front Plate Replacement: passo 4, imagem 1 %32 Sony Alpha 5100 Front Plate Replacement: passo 4, imagem 2 %32
    • Pop the memory card door open by gently lifting the door up.
    • Remove two 2mm Phillips #00 screws from the side of the camera.
    • Remove three 2mm Phillips #00 screws on the bottom of the camera.
  5. Sony Alpha 5100 Front Plate Replacement: passo 5, imagem 1 %32 Sony Alpha 5100 Front Plate Replacement: passo 5, imagem 2 %32
    • Use the opening tool to gently pop the front plate apart from the body.
Conclusão
Kevin Raggiani
Membro desde: 10/30/19
444 Reputação
Autoria de 3 guias
Equipe
UMass Dartmouth, Team S4-G6, Saloman Fall 2019 Membro de UMass Dartmouth, Team S4-G6, Saloman Fall 2019
UMASSD-SALOMAN-F19S4G6
Membros da 3
Autoria de 8 guias
Um comentário
Hi, i need to access the shutter-on/off switch on my a5100. Which parts and screws do i need to take apart.?
Thank you,
Fabian,
Fabian - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 11
Últimos 30 dias: 40
Duração total: 1,255
