Introdução
Is there water getting into the case? Maybe it fogs up with moisture? Here is a simple guide on how to replace the gasket in the waterproof case in the Sony HDR-AZ1.
O que você precisa
To open the case, slide the tab located on the underside of the case to the “unlock” position.
Press in the tabs, that are on the sides of the unlock tab, and pull down. This should cause the lid to open.
Remove the lid.
To place a new gasket in, follow these steps in reverse order, making sure the gasket is fully pushed back in around its entire perimeter.
