Ir para o conteúdo principal
Sony Action Cam HDR-AS15 O-Ring Replacement
O que você precisa
  1. Sony Action Cam HDR-AS15 O-Ring Replacement, Open the Waterproof Case: passo 1, imagem 1 %32
    • To open the case, push the yellow "Open" tab located at the bottom of the case.
    • Pull out on the yellow tabs as indicated by the circles in the photo to unlock the lid. This may be a little tricky!
    • Then, remove the lid.
  2. Sony Action Cam HDR-AS15 O-Ring Replacement, Pry the O-ring from the Groove: passo 2, imagem 1 %32
    • Take the plastic opening tool and wedge it between the O-ring and the groove.
    • Then, pry the O-ring until it is out of the groove.
  3. Sony Action Cam HDR-AS15 O-Ring Replacement, Remove the O-ring: passo 3, imagem 1 %32
    • Now that the O-ring is out of the groove, remove the O-ring from the lid.
Conclusão
Justin Calean
Membro desde: 01/09/15
421 Reputação
Autoria de 4 guias
Equipe
USF Tampa, Team 1-2, Sullivan Winter 2015 Membro de USF Tampa, Team 1-2, Sullivan Winter 2015
USFT-SULLIVAN-W15S1G2
Membros da 4
Autoria de 12 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 4
Duração total: 866
