Ir para o conteúdo principal
Sony Action Cam HDR-AS15 Memory Card Replacement
  1. Sony Action Cam HDR-AS15 Memory Card Replacement, Getting to the Memory Card: passo 1, imagem 1 %32
    • To access the memory card, push left on the rear of the Action Cam. The rear panel should easily slide to the side.
  2. Sony Action Cam HDR-AS15 Memory Card Replacement, Removing the card: passo 2, imagem 1 %32
    • After sliding the rear panel to the side, open the door outward to reveal the memory card slot and battery tray.
    • Push in on the back of the memory card with the tip of your finger until you feel a click.
    • Pinch the rear of the memory card that is protruding from the slot and pull on it until the memory card is removed.
Conclusão
Justin Calean
Membro desde: 01/09/15
421 Reputação
Autoria de 4 guias
Equipe
USF Tampa, Team 1-2, Sullivan Winter 2015 Membro de USF Tampa, Team 1-2, Sullivan Winter 2015
USFT-SULLIVAN-W15S1G2
Membros da 4
Autoria de 12 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 5
Duração total: 680
