Ir para o conteúdo principal
Sony α6000 Flash Assembly Replacement
O que você precisa
  1. Sony α6000 Flash Assembly Replacement, Battery: passo 1, imagem 1 %32 Sony α6000 Flash Assembly Replacement, Battery: passo 1, imagem 2 %32
    • Begin by placing the camera facing upside down.
  2. Sony α6000 Flash Assembly Replacement: passo 2, imagem 1 %32 Sony α6000 Flash Assembly Replacement: passo 2, imagem 2 %32
    • Slide the notched locking bar on the battery compartment from LOCK to OPEN.
  3. Sony α6000 Flash Assembly Replacement: passo 3, imagem 1 %32 Sony α6000 Flash Assembly Replacement: passo 3, imagem 2 %32
    • Push the small blue bar horizontally off of the battery.
  4. Sony α6000 Flash Assembly Replacement: passo 4, imagem 1 %32 Sony α6000 Flash Assembly Replacement: passo 4, imagem 2 %32
    • Extract the battery.
  5. Sony α6000 Flash Assembly Replacement, Flash Assembly: passo 5, imagem 1 %32
    • Position the camera with the flash assembly facing upwards.
    • Locate the flash assembly.
  6. Sony α6000 Flash Assembly Replacement: passo 6, imagem 1 %32
    • Open the flash assembly.
    • Using the Phillips #00 screwdriver, remove the single screw beneath the flash assembly.
  7. Sony α6000 Flash Assembly Replacement: passo 7, imagem 1 %32
    • Remove the eye guard.
  8. Sony α6000 Flash Assembly Replacement: passo 8, imagem 1 %32
    • Position the camera with the LCD screen facing upwards.
    • Pull back the LCD Screen.
    • Using the Phillips #00 screwdriver, remove the three screws beneath the viewfinder.
  9. Sony α6000 Flash Assembly Replacement: passo 9, imagem 1 %32
    • Position the camera with the HDMI port facing upwards.
    • Using the Phillips #00 screwdriver, unscrew the single screw on the left side of the camera body.
  10. Sony α6000 Flash Assembly Replacement: passo 10, imagem 1 %32
    • Position the camera with the top panel facing upwards.
    • Carefully separate the top of the camera from the body using plastic opening tool.
    • Be careful not to break the top of the camera when removing the top panel.
  11. Sony α6000 Flash Assembly Replacement: passo 11, imagem 1 %32
    • Position the camera so the top panel's underside is facing you
    • Using the Phillips #00 screwdriver, unscrew the screw underneath the flash assembly.
  12. Sony α6000 Flash Assembly Replacement: passo 12, imagem 1 %32
    • Carefully remove the flash assembly from the top pannel
Conclusão
4 outras pessoas executaram este guia.
3 comentários
Anyone know where to get the flash? My daughter’s has the “won’t stay closed” problem so common to the a-series and I need to replace it.
David Reeves - Responder
Thanks, good guide but please update it according to Jürgens comments or there is a big risk people will break their top panel.
David: I got the flash unit from AliExpress, but you can find it on Ebay as well.
Dan Lilliehorn - Responder
Thanks for the guide! I had to open additional 2 more screws inside the battery compartment. and only had to remove 2 bottom screws on Step 8 (instead of 3). Replaced the flash unit without any issue. Thank you!
Dustin Nguyen - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 14
Últimos 30 dias: 79
Duração total: 3,305
