Ir para o conteúdo principal
Sonos Play 5 Tweeter Replacement
O que você precisa
  1. Sonos Play 5 Tweeter  Replacement, Front Panel Assembly: passo 1, imagem 1 %32
    • Disconnect any power to the speaker and wait a few minutes for the capacitors to fully discharge.
    • Flip the speaker upside down.
    • There may be a rubber foot covering the bottom screws (not included in picture). Remove this by pulling up from one of the corners using a spudger.
  2. Sonos Play 5 Tweeter  Replacement: passo 2, imagem 1 %32 Sonos Play 5 Tweeter  Replacement: passo 2, imagem 2 %32
    • Remove eight 10mm Phillips #2 screws
    • Remove the bottom panel by pulling upwards.
    • Be very gentle with the ends of the three antennas. They are very fragile.
  3. Sonos Play 5 Tweeter  Replacement: passo 3, imagem 1 %32 Sonos Play 5 Tweeter  Replacement: passo 3, imagem 2 %32 Sonos Play 5 Tweeter  Replacement: passo 3, imagem 3 %32
    • Flip the device so that the grille is facing up.
    • Locate the line on the right side of the speaker where the grill and the plastic meet, and place your plastic opening tool in the gap.
    • Run the spudger along the gap, loosening the grille from the plastic. Repeat this process on the left side as well.
    • Gently pull up on the grille, removing it from the front panel.
  4. Sonos Play 5 Tweeter  Replacement: passo 4, imagem 1 %32
    • Remove the six 8mm Phillips #2 screws.
    • Remove the two 10mm Phillips #2 screws.
  5. Sonos Play 5 Tweeter  Replacement: passo 5, imagem 1 %32 Sonos Play 5 Tweeter  Replacement: passo 5, imagem 2 %32
    • Locate the line on the right side where the front panel and back panel meet. Place a plastic opening tool in the gap, and run it along the gap. Repeat this on the left side.
    • Use the opening tool to lift the front plate. If a plastic tool is not providing enough leverage, use a metal opening tool.
    • Gently pull up on the face plate to ensure it has been detached from the enclosure.
    • When pulling on the face plate be cautious because it is still connected by wires on the back of the plate.
  6. Sonos Play 5 Tweeter  Replacement: passo 6, imagem 1 %32 Sonos Play 5 Tweeter  Replacement: passo 6, imagem 2 %32 Sonos Play 5 Tweeter  Replacement: passo 6, imagem 3 %32
    • Lift up the front panel, forming a 90 degree angle with the back panel. Locate the locate ten pin connector shown. This is the wire that connects the front panel to back panel.
    • Press down on the small tab located on the connector. With the tab firmly pressed down, pull the connector out from its socket.
    • The faceplate assembly is now fully detached from the rest of the speaker.
  7. Sonos Play 5 Tweeter  Replacement, Tweeter: passo 7, imagem 1 %32 Sonos Play 5 Tweeter  Replacement, Tweeter: passo 7, imagem 2 %32 Sonos Play 5 Tweeter  Replacement, Tweeter: passo 7, imagem 3 %32
    • Locate the Tweeters on the back of the front panel assembly.
  8. Sonos Play 5 Tweeter  Replacement: passo 8, imagem 1 %32 Sonos Play 5 Tweeter  Replacement: passo 8, imagem 2 %32
    • Remove wires connected to the Tweeter.
  9. Sonos Play 5 Tweeter  Replacement: passo 9, imagem 1 %32 Sonos Play 5 Tweeter  Replacement: passo 9, imagem 2 %32
    • Lightly push down on the tweeter and then twist it out gently counterclockwise.
    • Gently lift the tweeter out.
Conclusão
Uma outra pessoa concluiu este guia.
Warren Girouard
Membro desde: 02/20/17
309 Reputação
Autoria de 2 guias
Equipe
USF Tampa, Team S3-G6, Sullivan Spring 2017 Membro de USF Tampa, Team S3-G6, Sullivan Spring 2017
USFT-SULLIVAN-S17S3G6
Membros da 4
Autoria de 16 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 3
Últimos 7 dias: 7
Últimos 30 dias: 35
Duração total: 3,221
