Introdução
The mid-woofer ensures the faithful reproduction of mid-range frequencies crucial for accurate playback of vocals and instruments, while also delivering a deep, rich bass. If it seizes to function the audio out put of the device will be greatly inhibited. This guide gives a step by step procedure on how to dismantle and replace the mid-woofer speaker.
O que você precisa
Remove the rubber footing from the bottom of the device. Pry it up from one end using one of the plastic opening tools.
Once you pry open one end, use precision tweezers to remove rubber footing.
Remove the four 9 mm Torx Security #9 head screws. There are two on each side.
Using a plastic opening tool, remove the grey tape from both sides of the device.
Remove the two 9mm Torx #9 screws fastening the power cable to the housing.
Remove the power cable.
15 outras pessoas executaram este guia.
41 comentários
Step 12 omits the connection to the Wi-Fi board. It's attached behind the hand in the picture and removing two T7 screws lets it slide out.
Where can i buy a new mid-woofer speaker?
Hi you have notice for midWoofer? asmaccocell@gmail.com
asmacco -
Nice guide. But without a matching replacement speaker, or at least specifications, it is useless. Even worse: without opening my Play:1 would be accepted at Sonos support :(
true true ))
totally pointless
whats the specs to replace the subwoofer
montpc74 -
