Introdução
This guide is for the replacement of tweeter diaphragm for the Sonos One.
Important: Accessing the internals of the Sonos One will void the factory warranty and make the unit rejected for factory repair, even if warranty is expired.
O que você precisa
Disconnect all power cords.
Remove the rubber foot and plastic screw guard on the bottom of the device using a plastic opening tool.
Note: the rubber foot and plastic screw guard can be removed as one piece to make reassembly easier
Remove the four 9mm Torx T8 screws from around the perimeter of the control panel.
Remove the six 9mm Torx T8 screws from the motherboard panel.
