Introdução
This guide is for the replacement of the metal housing for the Sonos One.
Important: Accessing the internals of the Sonos One will void the factory warranty and make the unit rejected for factory repair, even if warranty is expired.
O que você precisa
Disconnect all power cords.
Remove the rubber foot and plastic screw guard on the bottom of the device using a plastic opening tool.
Note: the rubber foot and plastic screw guard can be removed as one piece to make reassembly easier
4 outras pessoas executaram este guia.
Um comentário
Well done! I would add a little bit about how much adhesive there is underneath the rubber feet as well as the screw cover.
