Introdução
This guide is for the replacement of the control panel and microphones for the Sonos One.
  1. Disconnect all power cords.
    • Disconnect all power cords.
    • Remove the rubber foot and plastic screw guard on the bottom of the device using a plastic opening tool.
  2. Remove the four 10mm Torx T10 screws from the bottom of the speaker.
    • Remove the four 10mm Torx T10 screws from the bottom of the speaker.
    • Remove the bottom cover by squeezing the protective cover slightly while pushing up with your fingers.
    • The protective cover clip is very thin and deforms easily.
    • Remove the single 8mm Torx T10 screw and protective cover clip.
    • Slide the protective cover upwards to remove.
    • Use the pointed end of a spudger to remove the covers that hide the screws.
    • Remove the four 9mm Torx T8 screws from around the perimeter of the control panel.
    • With the front of the unit facing you, lift the control panel up using your thumbs.
    • There's a ribbon cable attaching the control panel to the speaker so work slowly.
    • Use a spudger to flip up the retaining flap on the control panel ribbon cable ZIF socket.
    • Pull the control panel ribbon cable out of its socket.
    • Pull the control panel away from the speaker to separate.
Conclusão
Marcus Glowa
653 reputação
5 Guides authored
Equipe
USF Tampa, Team S2-G1, Nance Spring 2018 Membro de USF Tampa, Team S2-G1, Nance Spring 2018
USFT-NANCE-S18S2G1
3 Membros
5 Guides authored
Visualizar Estatísticas:
Últimas 24 horas: 4
Últimos 7 dias: 28
Últimos 30 dias: 123
Todo: 641
