Esta versão pode conter edições incorretas. Mude para o último instantâneo verificado.
O que você precisa
Este passo não foi traduzido. Ajude a traduzi-lo
Start by using a spudger or plastic opening tool to remove the bottom cover.
Once enough of the glue is removed, peel the cover off by hand,
Remove the four 7.5mm length Philips head screws under the rubber cover.
Use a nylon spudger to unsnap the bottom from the sides.
Pry until the remaining three points are unsnapped.
Once unsnapped, lift the cover.
Remove the connection for the front buttons to fully remove the cover.
Use a plastic opening tool or spudger to remove the adhesive covering the the WIFI connectors.
Gently pull the wires at the connection point to disconnect them from the motherboard.
Remove the two pieces of glue holding the WIFI card in place.
Scrape the glued pad underneath the WIFI card to seperate the card from the board.
Push apart the two clips holding the WIFI card in the connection.
Pull the WIFI card out of the connection.
Remove the 7mm length Phillips screw holding the board in place.
Disconnect the Molex Cable from the top motherboard.
