Introdução
There are two boards for the device, a green top level and a blue lower level. This guide will show the steps to replace the top motherboard.
Ferramentas
Peças
Nenhum componente especificado.
Start by using a spudger or plastic opening tool to remove the bottom cover.
Once enough of the glue is removed, peel the cover off by hand,
2 outras pessoas concluíram este guia.
