Ir para o conteúdo principal
Sonos Bridge Power Port Replacement
O que você precisa
  1. Sonos Bridge Power Port Replacement, Power Port: passo 1, imagem 1 %32
    • The rubber bottom is glued on, meaning it can be easily pried off using the metal spudger.
    • You may have to pry from multiple locations.
  2. Sonos Bridge Power Port Replacement: passo 2, imagem 1 %32 Sonos Bridge Power Port Replacement: passo 2, imagem 2 %32 Sonos Bridge Power Port Replacement: passo 2, imagem 3 %32
    • There is one screw in each corner of the base for a total of four screws.
    • Remove each screw using the Phillips 1 screwdriver.
    • The four screws are each 0.9 cm long.
    • The screws are small, so be careful to not lose them.
  3. Sonos Bridge Power Port Replacement: passo 3, imagem 1 %32 Sonos Bridge Power Port Replacement: passo 3, imagem 2 %32
    • Use the metal spudger to pry out the plastic bottom.
    • Alternatively, the casing can be lightly tapped on a table (base down) to drop the bottom out of the casing.
  4. Sonos Bridge Power Port Replacement: passo 4, imagem 1 %32 Sonos Bridge Power Port Replacement: passo 4, imagem 2 %32
    • Pry out the circuit board.
    • Place the metal spudger under the board on the side opposite the two ports.
    • The board can then be easily wiggled out of the casing.
    • This should NOT require significant force.
  5. Sonos Bridge Power Port Replacement: passo 5, imagem 1 %32 Sonos Bridge Power Port Replacement: passo 5, imagem 2 %32
    • Locate the Power port on the circuit board, shown with the red box in the first image.
    • Locate the solders attached to the Power port.
    • Use the soldering iron to undo the solders.
Conclusão
Brian Strader
Membro desde: 11/07/17
201 Reputação
Autoria de 2 guias
Equipe
IUPUI, Team S3-G4, Harley Fall 2017 Membro de IUPUI, Team S3-G4, Harley Fall 2017
IUPUI-HARLEY-F17S3G4
Membros da 3
Autoria de 2 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 2
Últimos 30 dias: 13
Duração total: 1,230
