Ir para o conteúdo principal
Solving slow moving ceiling fan with remote control
O que você precisa
Vídeo de Apresentação
  1. Solving slow moving ceiling fan with remote control, Capacitor (depends on brand): passo 1, imagem 1 %32 Solving slow moving ceiling fan with remote control, Capacitor (depends on brand): passo 1, imagem 2 %32 Solving slow moving ceiling fan with remote control, Capacitor (depends on brand): passo 1, imagem 3 %32
    • Specification for capacitor are sometimes printed at the size. This brand uses 0.82uF 275V capacitor. Specification varies with brand.
  2. Solving slow moving ceiling fan with remote control: passo 2, imagem 1 %32
    • It will be so much easier if the board can be clamp down using the board repair clamp to hold the board while desoldering the correct capacitor.
  3. Solving slow moving ceiling fan with remote control: passo 3, imagem 1 %32
    • Simple suction pump required to remove the molten fuse.
  4. Solving slow moving ceiling fan with remote control: passo 4, imagem 1 %32
    • Cut off the excess length using a tiny cutter after a new capacitor is being soldered onto the board.
  5. Solving slow moving ceiling fan with remote control: passo 5, imagem 1 %32
    • Test the fan if it is moving at maximum speed after the capacitor is being replaced before assembling it.
Conclusão
Test the board if working before reassembly the circuit board back into the ceiling fan.
SengChoy Liew
Membro desde: 03/12/12
969 Reputação
Autoria de 3 guias
Um comentário
Not worth it, going to trash it & buy simple fan.
Joe W - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 12
Últimos 30 dias: 26
Duração total: 4,229
